Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148279 times) previous topic - next topic
Reply #435
Reguardless, I have a new 302 Dizzy for the car from a Monarc. Will have it in the car soon, and hopefuly running. Will get the measurements to rest. Scott, do you want the info on the measurements on your general info thread? parts scores from yesterday include a passanger manual seat track, new DS2 dizzy, coil, and Lokar cables. Should have a Holley on the way too
Reply #436
Well, I HAD everything on and ready to go accept the carb stud nuts. Went out and got some, went to install. On the LAST one, the intake cracked where the stud goes into it. Got 2 small chunks of intake off of it. The stud hole is useless now, as is the intake. Currently looking for another to replace. Yippie, another day of hard work paid for my heartbrake at the end of the day. Thaks Fila
Reply #437
Quote from: jcassity;144669
i had to read this like three times and think about it twice as long.
SO>>>>>>>>>>>
In my case, i remved a DS2 dizzy and installed a towncar dizzy with no problems other than the correct oil pump shaft lenght.  the ds2 oil shaft was the same diameter but longer than the TFI shaft.
now,, the 232 v6 oil pump shaft is thicker so that would stand to reason that dizzy shaft would be thicker.
we are talking about 302's only. was the thicker shaft for the 3.8? is that what you mean?
what is a "ds2"?
i dont know about the v6's. i know on the non-roller 302 mustangs they used the smaller gear. when they went to roller cams, they used the larger one. the smaller one you cant find in a steel gear for roller cams, except from MSD.
1979 Ford Fairmont
[/B]
Reply #438
i wanna take a shot in the dark and guess DS2 = Duraspark II?
Mikey,
sorry to hear about your intake! Hope you find a replacement soon. Stick with it, you'll get 'er going eventually!
Reply #439
Quote from: 32VFoxBird;144841
what is a "ds2"?
ds2,,,, DurasparkII , sorry bout that.  Back to that diameter thing, your two diameters are probably separated by the v6/v8.?????
fila
yeah,, i would appreciate that measurement, im curious.
and for the bad luck,, just to let you know,, i had a "WHITE" cat cross my path tonight,, maybe im in for some good luck?  might wanna see about stealing the first white cat you see.,,,leave mine a lone:D
Reply #440
Quote from: jcassity;144848
no, 302 V8.
roller vs non-roller
steel gear vs iron gear
1979 Ford Fairmont
[/B]
Reply #441
oh,, gotcha,, not applicable in this situation but that is something i did not know.
so,,, roller blocks from 86up got which diameter dizzy shaft,,, ill bet it got the half inch one, correct?
Reply #442
Quote from: jcassity;144860
85 is when the mustang got the roller cam. it uses the .531" gear.
1979 Ford Fairmont
[/B]
Reply #443
Well, I'd have pictured but dad took MY camara on the road for a month. You'll have to take my word for the measurements. Will have them up a bit later, I just woke up
Reply #444
As for the new intake, I'm thinking summit stage 2 Street Strip intake
Stage Two Intake
For $129 it doesn't sound that bad and for when I built the new motor, it will fit right in
Reply #445
Got my manual pass seat track in today, cleaned out the car, found $2.45 in change under the seats in the car. I'm debating running new speker wire to the rears or not. I can't think of anything else I can really do
Reply #446
I got depressed last night about not doing anything, so I ran all new speaker wire. Tsunami AV wires to the amp/sub, 14 guage speaker wire to all 6 speakers, power to the sub, Pioneere 3.5" Tweeters in the dash, Pioneere 6x9's in the tail, and Alpine 6.5" in the doors. All that to the newer JVC headunit. Pulled the passanger seat and consule and run under that for the rear to give a clean look. Not too bad for one day of bordom... Hopefuly I can get that intake by next week and finally knock this motor thing out for a while.
Reply #447
Ok, Shopping list for summit withen the next few weeks are as follows, unless someone else has a good idea. Price limit is about $500 hit or miss $25:
Intake gaskets
Cam
May also either get  a Summit Stage 2 intake or an old school SVO intake off corral for $100 shipped.
Reply #448
Edited here and now:
SVO 4 barrel medium riser intake off Corral $100 Shipped
Accel 300+ ignition with rev-limiting          $60 Shipped
Valve Cover gaskets                                $20 from Summit
FMS Aircleaner and element                      $60 from Summit
Used Stang 8.8 2.73 TL minus brakes        $100 Local
E7's from a 351 soon enough                    FREE!!!!
Crown Vic style belt setup ( Alt and PS on same serpintine insted of 2 different belts) Free!!!!
Prochamber ( In the mail soon )                Secret but worth it
LOTS OF SIMPLE GREEN                          $40 maybe
Full tanks of Gas ( Preimum)                    $65 at the moment
_________________________________________________________
                                        Total: About $455 hit or miss
If anyone has anything here that I need or that I wanted to buy for this stage of the project, Pm me and I'll get you a MO out soon. I wana knock this thing out by next staurday
Reply #449
Remember,when you use 351 heads,you'll have to get the inserts for the bolt holes (head bolts) because the holes on a 351 head are bigger than a 302 head.Grab a set through Summit..
