Topic: Heater Hose Replacement (Read 1620 times) previous topic - next topic
I need to replace the molded heater hoses (both coming from the core) on my 88 5.0.  My shop manual shows one having the temperature control unit inline - but mine is on the manifold. I'm having trouble getting the right part #'s.  Most are 5/8" 90 degrees or cut to fit but these replacements need to bend 4 or 5 different ways. I can get the Ford # off of one of the hoses (same # as in the shop manual) but not the other.
Does anyone have a good resource to get the right part the first time?
88 Cougar LS 5.0
Take the hoses off and take them to the parts store with you. Also if you can't find the right ones makes some. With stright hose and some of those gates uni fit coils. They are rings that go over the hose so you can bend it and it won't colapse. you can make 90* bends or more or less with these. Most parts stores should be able to get you the right hoses.
just replaced mine a few weeks back, these are the part #'s i used (Advance)
#S63087-9.99
#S63726-6.99
I think one is 5/8, and the other is 3/4, just had to cut to length
Here's a snip from my research last year...
(I used the Ford 3/4" (E7SZ) and Motorcraft 5/8" (KH-195) cause that's what the dealer had listed).
Supply (pipe2) to heater core
  - 4 turns
  - 3/4" x 11.6"
  Ford............ E7SZ-18472-A (inc. restrictor)
  Motorcraft...... KHM-121 (discontinued) KY-2 (flex 3/4)
  ACDelco......... 14176S
  Dayco........... 80411 * 2 + 80423 (90deg connector)
  Gates........... 19606 - Heater To Pipe-2, W/O ATC CtF {Molded}
  Goodyear........ 63087/63037
  NAPA............ NBH11606 ctf
  Drive-rite......
Heater core to return (pipe1)
  - 3 turns
  - 5/8" * 12.5
  Ford............ E6LY-18472-C
  Motorcraft...... KH-195 / KY-1 (flex 5/8)
  ACDelco......... 16030M
  Dayco........... 80400 * 2 + 80422 (90deg connector)
  Gates........... 18705 - Heater To Pipe-1, CtF {Molded} (DAYCO xref = 87621)
  Goodyear........ 63138
  NAPA............ NBH10705 CtF
  Drive-rite......
Thanks, y'all.  That's what I needed.  I would normally have taken them off but anything I ask for will have to be ordered - sight unseen.  These part #s will get it done.
88 Cougar LS 5.0
