Topic: windsheild wiper sprayers (Read 1757 times) previous topic - next topic
alrighty guys, heres another one of my dilemmas.. im not getting any windsheild washing fluid to my windsheild....
i pull the lever back to do it and i get nothing
any faint ideas of what could be wrong?
On the 3.8s, the washer reservoir is stuffed into the driver side fender. The reservoir contains a pump that moves the fluid. To access the reservoir, you need to remove the driver side wheel and spashguard.
So, that being said...
#1 Check the fluid level. Duh. Does the reservoir hold fluid? If not, you’ve got a leak. If it holds fluid…
#2 Check for pump operation. With the car off, it should be loud enough to hear. If it is pumping w/o any output...suspect a clogged line. If it isn't pumping...
#3 Check for voltage at the pump. Check for 12V at the connector while pulling back on the stalk. (2 person job). If you get voltage...you probably have a bad pump. If you don't get any voltage...
#4 Check fuses and wiring for the culprit.
i replaced all the fuses...
so im guessin i have either a clogged line or a bad motor correct?
Most likely...
Visio FTW!
Nice, one picture is worth 1000 words.
I make some flow charts at work, never thought about here though.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
Both nozzles on my '86 were almost completely clogged. I could hear the pump working, but the fluid would creep out.
I removed the nozzles and blew them out with compressed air. It's like a brand-new system with a full spray pattern.
Try it.
I don't even know if my washer works. I haven't used it in three years. I just used the wipers for the first time in two years this past July. Can you tell I don't usually drive the bird in the rain?
