Topic: heater selection (Read 3063 times) previous topic - next topic
heater selection
alrighty guys, its getting colder out now... and thats fine and dandy.. i have heat.. but its not getting directed through anywhere except the the defrost vents thats it.. no floor heat no mix no vent no max/norm ac... (i dont have ac but still lmao)
anybody else have this problem?  help would be much appreciated :D
heater selection
default on the selector(no vaccum) is defrost. check your vaccum supply to the selector. probly got a leak someplace either behind the panel or near the accumulator bulb
heater selection
why thank ya sir.. that was greatly appreciated... i completely forgot it was a vaccume ran system... and i remember capping a vac. line off  when i rebuilt my motor..
problem solved
 i feel dumb now.
heater selection
wow... it seems like it's happening to alot of people lately.  Mine just happened to stop working this week also.  I don't really understand where to look for this missing vaccum but i'm sure it'll turn up sometime.
:pics-stfu:
 Project Thread with pics
heater selection
check your connections behind the glovebox.. and if you changed a heater core lately... you might have pinched the vaccume feed from the motor..  or in my case... just left it disconnected...
heater selection
i'm thinking it has something to do with ramping... maybe.  I'll check though.  Thanks.
:pics-stfu:
heater selection
I had a broken line on the firewall near the AC evaporator core. They tend to get brittle with age.
heater selection
You have a vacuum line running from the tree to a funky looking tee on the passenger side of the engine compartment.  That tee is a check valve as well.  It has three hoses off of it.  One from the tree, one to the heater box and one to the inner fender where the vacuum ball is located.  Check those connections.
heater selection
lmao, i allready got mine fixed :D
heater selection
well shiznit.  Anyone ever hear any "sounds" comming from the heater?  Kinda like a gurgle?  Anyway, i'm running late for work and it's dark out.  So it's still going to have to wait.  I don't ever remember seeing a heater control valve on my t-bird.  I thought it was all thermostat operated.
:pics-stfu:
heater selection
Update:  There is a vaccum t on my firewall.  And i have a broken line.  So I plan on fixing it today.  Thanks claude for the info.  But also i don't know what that gurgle sound is.  Maybe someone else has heard it.  I'll try to get a video of it making that sound.
:pics-stfu:
heater selection
Does it sound like it's coming from behind the dashboard?
I hope your core isn't going south...
heater selection
Mine used to gurgle... it was letting me know that half the coolant had escaped through the leaking water pump, and had been replaced by air.  Bubble-bubble-gurgle-gurgle...
heater selection
sounds too mechanical to be coolant.  And it is from behind the dashboard.  How long did you hear a noise before it went out?  I've heard this noise off and on for atleast a year.
:pics-stfu:
heater selection
Alright I got a question along the same line I just replaced the heater core and in the engine compartment below the core tubes is a small hose coming thru the fire wall thats leaking antifreeze, not fast just a drip every once in a while, what is it and is it just getting rid of excess antifreeze from where the core leaked down in the box, or what (cause i got no leaks anywhere.
