Topic: computer? (Read 1743 times) previous topic - next topic
computer?
will this one work?
E7TF-12A650-C3B
KE3177
A2
computer?
Work for what? As a door stop?
I imagine it will work for whatever it was meant to....
How about being a little less vague next time.....
computer?
yep, ok cool, i was looking for a good door stop.
computer?
its a computer, but i dont know what all the letters and numbers mean? its out of a 88 mustang, and i wanted to know if was a automatic.
computer?
Did you ask the guy selling it?If it's speed density and an automatic,it'll work.....as long as you install an H.O cam.
computer?
ok, thanks vinnie
computer?
so can a 1986 speed density computer work?
computer?
I'd just try this and see if it works...
computer?
Quote from: quicksilver;103835
if switching to a HO computer you must change the CAM theres no way around it
computer?
Yes,an '86 Mustang GT computer will work fine,as long as you change the cam.If you don't change the cam,it will not work.The cam (an H.O. cam) will give the engine a 351 firing order.The computer tells the injectors to fire in a 351 firing order,that way,everything works together.
computer?
ok, i just got a computer in i paid for a month ago..... and i have the cam. so im going to put it in right after i buy a traction lock and 3.73 guys.
