Topic: oo man, need help quick (Read 1206 times) previous topic - next topic
well, i have to decide with acouple minutes if i want these heads 120024297054, or should i just go with GT-40 heads off a explorer?
oo its on ebay.
I would still grab a set of gt40s off a exploder..you can only do so much with a e7 head...granted the gt40s are the best head out there but they get the job done alot better then the e7's.
basically, look at them both in stock form..you would pick the gt40's correct? so look at them both ported,etc...still pick the gt40s right? the gt40s just have a better base to work off of. and they have slightly larger valves, ebay auction says nothing about installing larger valves or nothing, just a set of e7s with new springs,roller rockers.
the milling doesnt mean they can take a big cam, cam could still hit the valves or springs still might not work with it,etc. the gt40 springs can handle up to .550 lift in stock form.
so i should just go with the gt 40's then?
will these work?180021853999
so will these rockers work with those heads? 180021853999
oo all these numbers are from ebay.
Quote from: quicksilver
FYI thats only one head
oo wow, im happy you caught that! i would have been one happy man..
