Topic: 5.0L Accessory Brackets (Read 1015 times) previous topic - next topic
I'm in need of all of the Accessory Brackets and Bolts from a 87-88 5.0L T-bird/Cougar engine.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
i got 2 sets, i'll see if i can dig em up, and come up with a price for you?
Sounds good Nate. I'm looking for the cast aluminum alternator bracket and cast aluminum p/s pump a/c comp. bracket. Also, looking for the steel brackets that go on the front and rear of the A/C comp. If you still have the bolts too, that would be great. If you have some pics of the parts or any part numbers on the parts that would be helpful also. Thanks again.
1988 Thunderbird
Accessory Brackets
If you still have a full set of accessory brackets, I'm interested.
Stroked and Blown
[SIGPIC]
