Topic: cams? (Read 1086 times) previous topic - next topic
cams?
i have read about tbird guys putting in a E303 cam. is it pretty risky to do with the valves. i know every engine is different and all but how much clearance would a E303 cam give for the valves?
cams?
I going to say you probably need Mustang pistons because they have valve reliefs. The only heads that might work are the Twisted Wedge heads by Trick Flow. I think that TurboCoupe50 runs those heads on a stock flat top short block with a big cam. The only way you'll be sure is to measure piston to valve clearance.
cams?
You need mass air,If it cleares without a gasket on the head turning
by "hand" you should be ok,It's close I checked it,You could go with a little less and not risk it.High r's. shiznit streches.
cams?
E-303 will work with TF Twisted Wedge heads & flat top pistons. Their spec sheet says: Maximum camshaft lift with factory flat top pistons: .540" lift
You will need to go mass air, like kitzdnm said.
2.5-inch Aluminized Duals w/Custom H-pipe, 3-Chamber lers, 3.55 Rear Gear, E-303 Cam, Trick Flow TW Heads, BBK 65 mm TB, Cobra Intake, Mass Air Conversion, 76mm C&L MAF System, FlowTech Ceramic Headers, BBK UD Pulleys, 2800-3000 RPM Torque Converter, SCT Custom Chip.
