Topic: question on maf meter and sensor (Read 1882 times) previous topic - next topic
hey i just purchased a 70 mm mas air meter and sensor but it is calaborated for 19 pounds of fuel.. is it possible to get it calaborated for 24 pounds?? what will i have to change . and were can i have it done . is it worth calboated to 24 or just buy one already doen for 24's .. let me know thanks
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
I was told only to use Pro-M mass air meters so thats what I've always bought and never had a problem with any of them. I wouldn't run that meter even if someone said they cal'd it. Your talking about going to 24#ers so your looking to make some power than you will want a 75mm or 77mm meter anyway.. I'd say the 70mm will be too small.
So just get a pro-m for 24# is what I would do
were can i get one and how much is it
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
A big ol' MAF meter and 24lb injectors will do absolutely nothing for you with HO heads and cam...way too much fuel flow.  Aftermarket heads, big cam and a good flowing intake will be able to make good use of a big MAF and 24lb/hr injectors.
Oh your going to do HO swap, like sick88tbird says you only need 19# injecters and stock mass air meter will be fine. Also you can say screw the mass air and just run a HO speed density computer, some people say it will run stronger than stock HO w/ mass air..
noononon  no more ho swap i gotta take that out my sig im gonna rebuild my engine with a trick flow wedge heads kit that includes a cam intake and such and get some new pistons as well as boreing out teh block. so  is that maf meter and sensor i showed u good for the project??
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Yeah get the pro-m 75 and 24 #ers than. I bought mine on ebay... Injectors and meter for $200.. Try the corral.net classifieds too
fuel injectors and the meter/sensor for 200 u foudn for??
o0o0o0 man let me know were
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
o00oo0 shiznitT  thanks so much bro for lookin that up for me.. i really appreciate it
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Hey what short block you using for the trick flow kit? you building up a short block too?
the block from the 5.0 standard that i have right now
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
