Topic: "Master" NAPA Part #'s Thread Updated 4/18/07 (Read 24477 times) previous topic - next topic
OK, since I'm coming home with new part #'s daily, I'll keep updating this one "master" list.
83-86 TBird/Cougar
6021528 - Left Front Motor Mount Bushing 3.8/5.0, $41.99
6021529 - Right Front Motor Mount Bushing 3.8/5.0, $41.99
87-88 TBird/Cougar
6121649 - Left Front Motor Mount Bushing 3.8/5.0, $31.49
6021649 - Right Front Motor Mount Bushing 3.8/5.0, $43.99
49295 - Remanufactured Wiper motor, $76.99
6551837 - Drivers window motor, $74.99
6551836 - Passenger window motor, $74.99
6551128 - Window regulator gear kit, $27.99
6651557 - Windshield Washer Pump, $16.49
93274 - Transverse Parking Brake Cable, $14.49
93658 - Front Parking Brake Cable, $16.99
93236 - Intermediate Parking Brake Cable, $25.99
93634 - Left Rear Parking Brake Cable, $27.49
93638 - Right Rear Parking Brake Cable, $27.49
89000 - Brake Booster Check valve, $8.99
85594 - Front disc, $56.49
6401263 - 10" rear drum, $59.99
6401274 - 9" rear drum, $47.99
37697 - 10" drum Left rear wheel cylinder, $11.99
37698 - 10" drum Right rear wheel cylinder, $11.99
37400 - 9" drum rear wheel cylinder, $10.69
87-88 TBird Turbo Coupe specific
82472 - Front Caliper Housing Bolt, $7.49
83002 - Rear Caliper Housing Bolt, $10.99
893 - Front Caliper Boot Seal Kit, $2.99
1967 - Rear Caliper Boot Seal Kit, $11.69
37723 - Slave Cylinder, $53.49
6701115 - Clutch Pedal Pad, $5.49
XTP206 - Remanufactured LA3 computer, $109.00
XP357 - Remanufactured LB3 computer (auto), $114.00
AE7082DM - Front Pads, $59.99
AE7239A - Rear Pads, $43.99
86017 - Front Disc, $62.99
UP 560050 - Reman ABS computer, $374.00 plus $100.00 core charge
UP 540105 - Reman ABS master cylinder with accumulator, $1,769.00 plus $100 core charge
ALL 1983-1988 TBird/Cougar
7354552 - Passenger black metal door handle, $25.49
7355082 - Drivers black metal door handle, $22.49
7354552 - Passenger chrome metal door handle, $31.99
7351587 - Drivers chrome metal door handle, $28.99
6755159 - Door roller pin, $5.69
6755170 - Door Striker Bolt, $9.99
7302997 - Drivers mirror glass, $9.69
XTP220 - Remanufactured A9L 5.0 Mustang computer, $111.00
2299 - 10" Rear drum brake parts kit, $8.49
2438 - 9" Rear drum brake parts kit, $6.99
81164 - 10" Rear drum brake hold down kit, $6.49
80438 - 9" Rear drum brake hold down kit, $6.49
80457 - 10" Rear drum brake hold down spring, $0.69
80852 - 9" Rear drum brake hold down spring, $0.99
2.3L SOHC Turbo Engine
GS33328 - Head Bolts, $41.99/set
Sticky Please!!!!
It would help to know what brand those parts are. That way if we had to interchange the numbers we could also offer what brand number that is. I could add numbers from the store I work at.  Just so we had more than one brand of numbers just incase we can't find or interchange the ones you gave. I know the computer at work will give me motorcraft,A/c delco numbers besides our brands.  I work tomorow so I'll try to add some here after that.
Looks stickyworthy to me. I'm also gonna put it in the "Greatest Hits" secton eventually (won't while it's still active). We can all help, too, by adding part numbers for anything we buy for our cars. I'll be adding a bunch when I dig out the receipts for my front end parts.
Michael: I'll just edit your post with my part numbers when I add them, and I'll edit it each time somebody adds numbers (or you can edit it yourself) so they'll all be in a single post
Parts Reference
I won a bid on eBay for a 95 Cougar steering wheel while waiting for the seller's reply to whether or not it was of any use on my 97 XR7.  He never did suggest anything better than asking my dealer (like they are going to help me buy a used part).  I've taken the hit on ebay for not paying, but still wonder if I could use this wheel?  My cruise control is missing buttons and my leather is failing all around the grip, so I need a wheel, it was a fair price, just can't see paying $.02 for a wheel I can't use.  Is there some reference I can go look at that would tell me which years this wheel can be used on?:dunce:
Parts Reference
Is that for an 87/88 TC or is it full-line?
PS - Sorry I've been slacking on this :(
I think it is for the full line but I looked it up for my TC, I'll do some looking and edit this post.
*EDIT*
this is for the full line. except...
Strut Mount - Front Suspension
Available at NAPA stores. This part can only be purchased from your local NAPA Auto Parts store.  ATM
KSM5187
Except Adjustable Suspension
there doesnt seem to be any part listed under this part number though
this was looked up under 1983 thunderbird 3.8
new part add .........NAPA
control arm bushings
front of control arm pn 2673351, 2.4'' od = 30bux
rear  of control arm  pn 2673512, 1.9''od = 18bux
the brake pads # are changing to UP7082DM and UP7239A.... instead of the AEs, same pads .
88 thunderbird, 306 ,E7 heads ported by me, explorer intake, 70mm professional products TB, 8.8 3.73 rear is finally in. 11" front brake upgrade. still need some stuff
some nice weather to work on stuff would be nice ^^^
I have the same magnaflow too and love it, you can usually get a used one on ebay or cragislist.  I wanted a valid warranty so I got it here. Magnaflow 93236.  Also some of the forum sponsors usually have a sale going on.  Either way its a great exhaust system, sounds great, and very easy to install.
