Topic: Wiring diagram (Read 1357 times) previous topic - next topic
Wiring diagram
anyone have a detaled wiring diagram for an 88 turbocoupe?
2 88 TC's (1 is the 2.3t race car, other v8 maybe?)
06 dodge dakota 4.7 v8
79 chevy k-10, built 350/turbo 350
Diverse ain't I?
AMSOIL Dealer
Wiring diagram
http://www.foxthundercats.net/samscars.htm
yeah right here.
*edited by Thunder Chicken to fix link*
Got that fox rash again!
-Resident smartass! :ies:
Wiring diagram
HELP............  I need help with my air conditioner.  I have a 84 couger xr7.  When I turn the a.c. on the clutch on the front of the pump does not lock in.  I have removed the electrical fitting and tested it with my test light and it shows no power.  I use the ''icepick'' type tester with one end grounded.  If you could help I would appreciate any advise.
Yes, I start the car and set the temp for cold and the switch for A.C. and turn on the fan blower which works fine. the real problem is that the clutch does not get power to energize and make the pump run.  Reply here or to seajaycecil@yahoo.com or send you phone number and I will call you .................
Tks    Seajay .........
Wiring diagram
Is there any refrigerant in the A/C system? If there's not, or if there's not enough, the pump will not run. If there is, you probably need a pressure switch (which, unfortunately, means you've got to let the refrigerant out again to replace it, IIRC)
