Topic: Fuel Pump No Go??? (Read 1681 times) previous topic - next topic
Fuel Pump No Go???
I have no fuel pressure and no power to the pump in the tank???
any info on where to go from here would be great!!!
codes
i pulled some codes out of the thing it came up with
41- o2 sensor
42- o2 sensor
72- B power circuit to  eec power relay?????
anybody help me with the last one?????
Fuel Pump No Go???
Check the relay in the trunk under the rear package shelf,near the inner fender,on the passenger side.Should be a green relay there.That was my problem.
Fuel Pump No Go???
Or it could be the fuel cut off switch....
Fuel Pump No Go???
I have the same problem with my 84, Should I use these same idea's to fix mine?
Fuel Pump No Go???
where is the fuel cut off switch???
Fuel Pump No Go???
I think it's in the trunk isn't it. A black box with a switch on it. If you push the switch it should reset it. I think
Fuel Pump No Go???
Quote from: 84 Fila
dont be so sure of yourself :nono: :giggle: :giggle:
Fuel Pump No Go???
Why I said I think. Like I said I'm having thes ame problem
Fuel Pump No Go???
Fuel pump inertia switch location:
1983-86 cars - by the right trunklid hinge, other side of the metal bar. There is actually a round cutout in the metal for the reset switch.
1987-88 cars - inside the trunk, driver's side, taillight panel. Cutout hole is in the panel liner.
Fuel Pump No Go???
So I was half right?
