Topic: 5 spd TBird pedals for sale (Read 1239 times) previous topic - next topic
Complete set of 5 spd pedals out of TurboCoupe with clutch and brake pedal, ready to go. Sell it for $45, reply here or in PM. Thanks!
bump
Anyone doin or goin to be doin a 5 spd swap need the clutch and brake pedals setup?
Will they work on any Fox body?
Quote from: Bird351
They will fit any Fox-chassied car, but the 87-88TC's used a hydraulic clutch set-up.  The rest of the TC's and the Foxes used a cable.....
But I'm guessing that's not a problem if you're adding a stick to a car that didn't originally have it.. to, say, a Mark VII..? Could just add the whole hydraulic setup, right?
Again....only the 87-88 2.3T's use the hydraulic, EVERY other Fox car with a manual was a cable clutch....
There were no 5.0 Foxes w/ a hydraulic clutch...thus no 5.0 hydraulic bellhousing.
So what kind of clutch does a T56 usually use? I'm not interested in a T5 swap. If I convert one of my Foxes to manual, I'm goin' all the way.
EDIT: One big possibility is that if I do a manual swap, it would be to a 2.3T Fairmont or Zephyr. I'm looking at one Zephyr right now, (hence why my 86 is up for sale as well as my 351W) and it's an automatic. I could possibly use a T5 until I could afford to go with the 56. I just threw out the Mark thing as an example. (that's more likely to get an AOD with 4R70W internals than a stick.. but anything's possible)
Looks like Chuck gave up.. heh.
Anyway, assuming no one else got to them already, I'd have some interest in trying to get these.. and I'll be selling/ebaying a few things when I get back from vacation to try and raise some money for car work, so I'd actually be able to afford something for a change.. but I'm sure someone else will jump on this before I get back.. so I'll catch the next set that comes along if that's the case. Good luck.
