Topic: cam selection (Read 1344 times) previous topic - next topic
cam selection
what cam should I put in my GT40P 5.0 that I'm building? stock torque convertor...3.08-3.55 rear gears...I'd like an all around decent cam *hydro roller* for the street and strip
cam selection
either a stock 87+ cam or an E cam.  about the the for street strip.  either those or call up the cam companies, theyll help you out alot.
cam selection
trick flow stage 1
http://store.summitracing.com/partdetail.asp?part=TFS%2D51402000&view=1&N=700+115
cam selection
guys talked into the trick flow stage one.heres the link hope it helps.
http://www.foxtbirdcougarforums.com/showthread.php?p=54854#post54854
cam selection
This one will work nicely if you're gonna go Mass Air.  The lobe separation is a little close for Speed Density......
http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=35-412-8
You could also go with Crower part #15511.  It has a little more duration and lobe separation than the cam in the above link with a little less lift.
If you're gonna go with 3.08's and the stock convertor I'd go with the Crower.
cam selection
forgot to add...it has a carb
cam selection
Quote from: 86Tbuzzard
Man it will sound good. You can’t beat the way a carburetor sounds especially w/a cam. Fuel injection is the best way to go all around except one thing. It runs on a little after you get off the accelerator and corrects the cam.
