Topic: Sticky Throttle (Read 1226 times) previous topic - next topic
Sticky Throttle
My throttle has stuck at wide open three times in the last day its pretty scary i think it something on the floor so i took my floormats out and looked for anything but i didnt see anything and i'm going to spray some wd40 in the cable shroud and on the return springs but if that doesnt take care of it is there anything else that could cause this.
2004 Impala
Sticky Throttle
Look under the hood and make sure you haven't lost a return spring or have one sticking.
88 Cougar LS 5.0
Sticky Throttle
My old 3.8 would do that on occasion.  Check to make sure your throttle cable and/or TV cable are not wrapped up or binding on anything as well.
Sticky Throttle
You said it only stuck at wide-open, so floor it.... with the engine OFF.
Check the throttle plate/bore for crud, the cable for fraying, the throttle shaft holes for wear that could let the shaft go off-center.
Sticky Throttle
just get a new cable from ford  definitely worth the 30 bucks i think
Sticky Throttle
So does it still stick after you took the floormats out?
Sticky Throttle
Nope no sticking since i took out the floormats they were getting pushed up under the pedals and i have aftermarket pedals and the bolts holding the accelerator pedal down were wedging in the mats so im going to work something out with hooks to hold them in place and replace the pedals.
2004 Impala
