Topic: Is It The Same Transmission??????!!! (Read 1474 times) previous topic - next topic
hey my car is a 88 t bird lx and it came with a 3.8 v6. Im swapping a 5.0 in it. My question is , what is the transmission that came with the 3.8 v6, by the way its column shifter. Also is it the same tranny that came with the 5.0's .  Or is it a weaker transmission.. PLEASE LET ME KNOW ITS URGENT!!!!!
thanks
ERIC
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
it is weaker in most cases, however, the tranny will work for a while behind the 5.0. Unless you are tricking out the 5.0, it should be fine for a while at least. Then you can save up for a better tranny.
. what tranmission do u reomment for speed wise and racing???
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Both the c4 and the AOD can be built up pretty stout, if your making big torque you can get a sb c6.
woudl u prefer a c-4 i think i can get a good deal on it and it had jegs super rebuilt kid in it, but the aod i hav is from a 3.8 so should i just gte a c-4 that im lookin at right now??
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
c-4 has no over drive. So good bye to freeway gas mileage. You could just beef up the stock aod by taking it to a tranny shop and tell them its for a mustang.
keep the aod, have it rebuild or buy a rebuilt one. theirs no need to go with a super duity heavy c4 or c6 and have to modify thing to make it fit and loose overdrive if your only doing a HO swap.  if anything, buy a good shift kit for it, and a external tranny cooler. that will keep your rebuilt transmission in one piece and let you beat on it for another 18 years
nate i added u to my aim man my screen name is queenznewera i wanna talk to u on aim about this.. ok
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
well its not just an ho swap i will be doing heads soon and possibly the cam .. i dunno i want which ever is better for street race and burn those little ricers!!
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
just get a shift kit with an aod and maybe some more clutches at a tranny shop. Oh and you might want to upgrade your rear end. to say 3.55 or 3.73 gears.
An honsestly, a stock tbird or cougar with a 5.0 is usally enough to toast a  civic or two.
Quote from: Haystack
Uhh.. right.
Anyway, you might want to upgrade the rear end to an 8.8 not just the gears.  My 7.5 lasted quite a while behind my AOD and HO.  My AOD is still going strong too.
And I sure hope a 5.0 can beat a Civic, those things are turds.  It's just kinda sad what a stock SO can't beat.
Willpower is no match for Horsepower.
okay, 99 down civic. The 5.0 aint a dog stock like most people say. Compaire it to other 86-88 3500lb cars and it still aint bad.
