Topic: Working on a friend's T-Bird - Rattling (Read 2070 times) previous topic - next topic
Ok, so a friend of mine from work bought a T-bird a while back, he drove it once and it overheated.  Apparently the radiator blew on it.
He replaced the radiator and so on.. but it didn't fix the overheating.  I took a look and fixed the overheating problem which was a crushed heater pipe.
But the car has a knock or a rattling sound coming from it.  It almost sounds like something rattling around in the engine bay like a pulley because sometimes it squeaks too.
Anyway, here's the two videos I took, can anyone identify the sound of it?  I'm hoping not rod knock, but you never can tell.  This car does have 220,000 miles on it.
Also, it's a 92 3.8 obviously.  How do you pull the codes on this thing?  It comes up once in awhile.
Two videos here ---
http://www.cougarnuts.com/MVI_0588.AVI (7.26MB)
http://www.cougarnuts.com/MVI_0589.AVI (3.70MB)
Both videos are very small, but I just took them for the sound.
Thanks for any help ahead of time.
Willpower is no match for Horsepower.
i cant view the videos cause of my poor connection.
but i had a very hi milage 3.8 once in a 85 fox mustang it made a rattling/ knocking noise and was the crank thrust bearing. check to see how far it moves for and aft.
That sounds EXACTLY like my probe gt when it spun a rod bearing.  Check with others though.  I'm about 80 percent positive.  Try to get information on how a thrown rod would sound as far as consistancy/repetiveness.  Do an oil change and look for shavings.
:pics-stfu:
 Project Thread with pics
oooooooooooooooooooooooooo,That's a rod,sorry man but it looks like you need an engine,i hate that sound.
Quote from: SLEEPER T-BIRD 87
^ this will also sound like a rod knock
Harmonic balancer coming apart?
Take the belt off and run it to eliminate all the belt driven stuff.
Sounds like a rod. Valves would make more of a ticking sound. It's gotta be a rod. It's knocking like an SOB.
You, sounds like a rod.  Probably towards the back (those like to go first on 5.0's as well as 3.8's)
Well thanks everyone, but I'm done working on it.  He's looking for a different car right now.  Car isn't worth as much as how much it would cost to fix it.
Thanks all.
