Topic: how much does your AOD take? (Read 4748 times) previous topic - next topic
TF 347, the flexplate is the same, you will need different bolts for the tranny and bellhousing, I bought a shifter but it was not really needed unless you want to be NHRA legal. I was bracket racing every weekend so I changed the shifter. The TCI AOD will only hold 450 hp cause it is still a lockup converter. When the AOD shifts into 3rd the "pencil shaft" that is the high and OD input shaft locks the torque converter to the input shaft eliminating slippage by the converter, sucks for performance great for gas milage. Now there are simple fixes to this, one option is a 1 piece input shaft that can be ordered from lentech and installed by your tranny guy. You will need a converter that is for your 1 piece input shaft as well, It will no longer lock up either. No problem if you want to put that power to the ground, cause you will not need a trunk full of clutches and bands for that wimpy stock AOD. What you need to make that performance motor work is a performance tranny, either way you will have to give up something (c4= No OD, AOD= Lightweight wallet) That is why I went with the C-4, I can buy 2 of those trannys for the price of 1 lentech, If i cared about gas milage the car would be a honda and I would be jaming to the latest techno track while thinking a fart pipe would be cool. Hell no, when I get cut I bleed american red, white and blue. Cars need brutal face distorting torque and nitrous, broken parts are sacrafices to the god of speed and you and I both are the priests of that religion.
Quote from: Lightningbird
HELL YEAH MAN YOU SAID IT
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
:iagree: I have 42lb injectors...what gas mileage, I burn 2 gallons just getting the car ready to leave the driveway! :D  Ive got a NX kit I havent been able to use yet too!:giggle:
lentechs have a lifetime warrenty so you should only need to buy one!;) I just need to decide between auto or manual....
1987 cougar XR7 347 stroker FRP BOSS block 328rwhp 10.89 1/4mile @126mph ..so far..
2005 F150 5.4 vortec supercharged @15psi water methenol injected 450rwhp 14.0@98mph on 22's
Quote from: TrickFlow347
TC50: 1st and 2nd are still hold'n up, but dont shift as hard as they did. I dont have a hardened imput shaft and havent had anybody around to help me get the trans down to see if thats the problem...Im not thinking that it is since the fluid is messed up....Are you saying your trans is STOCK! If you are Im headed to the s yard!:giggle:
Yes my trans is a NEVER apart '89 Super Coupe AOD. I bought it with 40K, still had the factory cherry bomb rolling around in the pan. Only mods are a Trans Go shift kit and the hardened inner shaft I already mentioned. I doubt I'd trust one these days, as you're not likely to find a low milage unit. Its up to approx 75/80K and is still shifting decent, although not as hard as when I first installed the kit... I'll need to have it rebuilt before the 347 goes in.
Heck, I still have the stock shaft, but I don't throw giggle gas at my car though....Tom has more balls than I do.
Quote from: mmvolnutt
i'd say turbocoupe5.0 is right, you probly broke that shaft.  whenever you bring in the transmission, talk to him and see if you can put in 4R75W internals.  i dont know how much different they are, but if the 03 Mach 1s and new F150s got it while the GT still had the 4R70W, then they should be stronger, im guessing.  i know they took out the 1-2 accumulator and replaced it with a rubber ball in the valve body, thats the major difference, but for a 3V motor to be on it, its gotta have some more stregnth.
The only difference between a 4R70W, and a 4R75W is 50 ft lb of torque rating, a different style of apply components for the intermediate clutches (the ones directly behind the pump), and an extra turbine speed sensor towards the front of the trans.  The 1-2 accumulator is still there.
Matt :tg:
Quote from: Paul Flockhart
Mine broke first time at the track on a shakedown run... No Juice... Had the B&M 2000 stall and street tires... Blotched the first run, only went 14.4(eased it out the hole with a 2.4 60ft). Next run with a fair 60ft(2.15) it snapped the inner on the 2-3 shift, should have gone a 13.8 or so(still went 14.74 with only two gears). Was running 19lb inj, stock 55mm M/A meter and a stock 5.0 stang exaust system.
Oh..it was special!  we got the trans down and the torque convertor was stuck in place, spining it made a sound like a skweeky belt, after a little tug of war with the tranny it came off with the 3rd imput shaft still inside it, with some chunkys, the 2nd shaft wobels inside the first, and 1st wobels inside the torque convertor and something is clanking around in there.  the trans pan had some chunkys and was full of friction material, now the first time I took it down it was too (w/o the chunks;) )but the tranny guy said it wasent worn so I passed it off like it needed to break in or something, but I dont think it should have that much in the pan after so little use this time. Oh it was also suposed to have a hardened imput shaft too.  So I guess no matter what trans i go with I need a new torque convertor anyways...
Oh yea... you have some new plans?  I suggest you upgrade your tranny better than a rebuild:D  And my car seems to be twisted so you might want some mighty sub frames too!:giggle: If I had it to do all over again I would have went with a stroked 351 or a world block, cuz right now I want to upgrade but I dont think I can push too much more hp. I love a good stroker motor it builds Rs quicker than shiznit!
help me pick a tranny...
Okay after looking at trannys I have some questions..
I dont see an AOD (besides a lentech) that holds more than 450hp so Im looking at C4s and C6s..what would be the pros/cons between these? Does the C6 hold more power? I saw most of the competition trannys were C6s..
Auto/manual? Youd have to be quick to hit that 1st shift! Probly would want a shift light or something right?
then... the forward or reverse shift patern? Is it just a preference or does it depend on your shifter?
I need a torque convertor that shares the same bolt pattern as my AOD so I dont need a flywheel.
26 or 31 spline? More is better? usually is....I Just want to make a good decision and be happy with the tranny I get.:D  I watched some highway races this last saturday, some were lookin for the cougar to be fixed so Im in a hurry now! maybe Win some of my money back!
Stock not much.
well the first question would be, what kinda of gears are you running?
If its a 3.73 or 4.11 it will be hard to hit, but that all depends on how fast you can shift. TC'shiznit it, al though alot slower, with a stick, or so I would imagine.
You also gain hp to the ground if you can get a stick that will handle the power, but then you lose alot of consistancy. Now, you have the gas and clutch to worry about, but it would make it alot more fun to drive IMHO. but clutching in traffic will get to you sooner or later.
Really its up to you.
Tranny Woahs, This is the question that everyone on this post should ask themselves when they build too much hp for the "factory" parts. AOD is an awesome tranny, just expensive, an AODE is another alternative, I believe it is the same length, handles more torque and does not have the "pencil" 3-4 shaft. C-6, hello modifications and welder (the x-member, driveshaft, shifter), Tremec TKO (face it T-5 is worse than the AOD) bangin gears rocks, based on your rear gears(3.73-4.10) I would find the highest first gear available cause shifts come awefully fast when you have 500+ hp. You will most likely never need another tranny if you have a manual, but cluthes are another story. Go with AOD/AODE or a C-4 they are the most cost effective and least amount of time intensive. I believe the AODE takes a computer to run, does anyone know? Maybe it is like a 700R4 or 2004R and you just need a switch. BTW if your input shaft is not broken in 2 then I would say it is hardened. Just your hub on the torque converter is not. I would try another hardened input shaft and a non locking torque converter with furnace brazed fins and roller brarings (precision Industries, TCI, High end B&M) after I cleaned the tranny and see if the AOD still works before spending another dime. After I bought all of the right stuff for my AOD it was the clutches that let go and the case broke not the input shafts. I bet it was the input shaft and it still works fine. BTW do any fwd gears work? if 1&2 work it has got to be the shaft, your shaft was harder than your converter and destroyed (I love using that word) the front lockup hub inside the converter. If you have the tranny apart have your tranny guy install a 1 piece input shaft and buy a lentech or precision converter that will work. I hope this helps.
My 1st and 2nd still worked but not as firm when I got the trans down the torque convertor was stuck in the tranny! We had to get it out by pushing it in and out with the help of a hammer!:shakehead  The TC is junk it jingels and clunks not to mention that the input shaft is still stuck in there...:rolleyes:
I couldnt find a clear answer for how to install a c4, so I took my AOD to my tranny guy and he said hes never seen that before!:eek:  Anyways hes taking it apart to see if its still good, he said the material in the pan was probly from the torque convertor cuz he runs the same trans on 800hp cars and if everything is still fine on the inside Ill go with a one piece shaft and a non locking convertor.
