Topic: Intercooler in non-turbo engine? (Read 1184 times) previous topic - next topic
Just wondering if there's a benefit to using an intercooler without a turbo or supercharger installed.  Does the cooling benefit get negated by the restriction of flow?  I'm just looking for ways to increase my car's hot weather performance, summer-time bogging really bugs me.
No.
Cooling ambient air with ambient air is not going to gain you anything.
Quote from: Chuck W
No.
Correct and you will probably make things worse by choking down the air
If you’re looking to cool your air there’s a product called MR.FREEZE I don’t know much about it other then its new. It might not even be for you.
build more power.... ?
~John~
Uh..what?
Basically, the purpose of the intercooler is to cool the air that has, essentially been heated up by the turbo.  It tries to bring it back down to a lower temp.  A fenderwell mounted intake (which these cars have stock) will achieve the same goal on a naturally aspirated car.
You need a CAI. Think about it. That same air you are trying to use to cool your intake charge could just be drawn into the system instead. Like Ifixyawata said, the turbo/supercharger heats up the air when it compresses it, hince the need for an intercooler to bring the temps back down to wart off detonation.
Furthermore there is a pressure drop due to the restriction of the intercooler. And it adds weight.
Get a CAI kit and maybe even a Ram-air kit or something. :)
I'd love to get a cold air kit but I don't think there's one made for my car.  The intake duct goes from a round hole in the fender to a rectangular hole in the air cleaner.  I'd probably need an aftermarket air cleaner.
