Topic: camber kit (Read 1532 times) previous topic - next topic
camber kit
yeah, you need about 4 sets....:flame:
Seriously, do you really think the back needs a camber kit...maybe you should re-consider lowering your car...
camber kit
Uh....no.
You don't need anything like that for a Fox car.
Also, the only way to adjust the camber on the rear is to bend the axle housing ;)
You need to spend more time looking at your car and less time reading about Hondas, etc.
camber kit
http://www.rockauto.com/catalog/x,carcode,1140297,parttype,7436
Also listed on Federal Mogul (Moog's home)
http://www.federal-mogul.com/aftermarket/us/moog.html?Country=USA
Catalogs, Make/Model Look-up, work your way through, and...
MOOG
 FRONT
Alignment Wedge
PROVIDES UP TO 1 1/2 DEGREES  CAMBER CHANGE
K8825  80-88
camber kit
Why the hell even spend money on those?  Without any mods to the strut, the're not going to change anything anyway.
Evidently they are made to wedge between the spindle and the strut, but you have to elongate the strut holes anyway.  Never had any problems with not using them.
camber kit
ok so my honda friend eric was wrong then. ok thanks bcuz he said it'll warp the inside of the tires
camber kit
Well aparently they do list those for the Tbirds, but they really aren't needed.  Alone they won't magically correct any camber issues.  YOu will have to mod the holes in the strut to allow for some adjustment where the spindle attaches to the strut.  I have had to do that numerous times, but have never needed the shim, even on track cars.
