Topic: 3.73 locker (Read 1202 times) previous topic - next topic
3.73 locker
Found a van in the JY  ,,, about mid 90's and it has a 3.73 locker.  Is this a good rear?
3.73 locker
If you mean an Aerostar then yes the diff will work, I've already asked about it because I'm doing the same thing ;) Would have it done already but PicknPull crushed the 97 Aerostar I was working on :mad: But if you're planning to swap the entire rear not just the diff then I'm not as sure.  I do know those axles are 5 lug not 4 like our cars.  And I think someone might have said the carrier housing is off center but I don't know that for a fact.  Hope this helps.
