Topic: WTB- Door Striker bolt (Read 1206 times) previous topic - next topic
I'm looking for the door striker in good shape (as in the plastic bushing is intact and good) for the TBird.  This is the part that bolts to the chassis.  The bushing is totally gone on mine.
Also, if you have the proper "HELP" part number instead that would be good too. I picked one up the other day and it looked like it was correct, but the threaded stud portion was too big.
Chuck
chuck@turbochuck.com
Uh, I just picked mine up from the HELP! section at Advance Auto for my '85 and '87.
I don't have the part numbers...I just compared it to what was on the car.
check the part store in the help section, they sell them here if you would like for me to get some and send them to you
I had the exact same problem.When i was at the jy we got some out of a 4 dr taurus. the bushings on the rear doors were just about perfect. Now the doors close just like new and they were free!!
Quote from: 8birdy8
I remember Claude telling me about that. He also mentioned the 4-door Escort or Escort wagon. The reason for the 4-door? The rear door strikers should be in much better shape than the fronts.
I replaced one of the strikers on my '86 with one from my '96, believe it or not.
Well like I said, I checked the HELP section and the one that fit "most Ford cars" didn't fit.  It looked like the one in the car, but was not.
Well doing some digging on the web, the HELP part number is 38445.  It differs from my stock on though in that it kind of a "fence" at the back of it whereas mine is just the striker bolt.
If I remeber right that extra piece just slides off and you only use the bolt part out of it. I'll double check at work and try to post on here at lunch normally about 1pm central time.
Actually zach its the tempo and c/v's the escort uses a puppiesanese design.
but anyways.. I've got a whole bunch of good ones.
hey chuck the number I get for the bird is 38448 it is 7/16"-10  and yes it has that extra piece of metal that you just throw out. Also the tempo part number is 38445 M10-1.50 , it also has that extra piece that you throw out. Also if you just need the plastic bushing part you can order 38424 that is a package of those bushings
Chuck, I just went through the exact same little frustrating thing as you with the Help brand's bolt being too big...
I just ended up getting a new set from Ford for both my doors. They were about 12.00/each, whick I know is pricey compared to the Help brand, but I was tired of not being able to find the right part!
