Topic: horn problem (Read 1128 times) previous topic - next topic
horn problem
my horns inop on my 86 t bird
hit the horn and nothing- no clicking or anything. checked fuses they all seem to be good- wheres the horn relay on this thing? thanks!
horn problem
Not sure about the relay but the horns are on the frame rails in front of each tire. Have they ever worked?  Have you tired pushing in twards the column on the turn signal switch? some cars came with that as an extra horn button.  Maybe the clock ring is toast. (the part behind the sterring wheel.  Maybe one of the wires right where it connects to the clock ring. Also most of the factory horns have a screw on  them near the wire plug try turning that sometimes that makes them work. Also maybe they are pluged up with dirt or rusted inside.  hope this helps. Sorry I don't know where the relay is.
horn problem
so i put a relay in- found it in aldata the ford manual is wrong- its above the glove box under the dash.
the relay didnt work:nono:  lol i always tell people to not throw parts at cars and to diag them correctly. i put the 12v to the horns and they worked, checked the ground going to the switch and hit the switch i got ground to the other side of the switch so i assumed it was the relay
i took the trim off the colum and it looks like the purple wire that turns into the yellow and green wire has an open in it- im gonna run out and get my puller now and pull the wheel and check the wireing out
horn problem
Ah, just do what I did with my Jeep, get a sticker that says "Horn broken, watch for finger"  lol, other than that, listen to everyone else, they at least know what they're talking about.
'86 cougar gone to the big yard.
'86&'88 Jeep Comanches.
horn problem
:D forgot to post yesterday- it was the purple wire- it was loose in the connector, got it tight and put it together and it all works now
