Topic: will these motor mounts work? (Read 1288 times) previous topic - next topic
Doubtful.
I'll be doing another small batch of mine in the near future if interest.
I think I've seen a set of them in MM&FF being used as motor mounts on a dyno...I thought the exact same thing...where did they get them and would they fit?...probably doesn't have the right offset though.
Quote from: Sick88Tbird
65-72 windsor mustang/fairlanes
1979 Ford Fairmont
[/B]
Those are made to fit a 45* mounting pad on the crossmember... '86-'88 Birds/Cougs use a  setup with a flat pad.... No worky...
If you just need insulators, the ones '89-'90 3.8 MN12s are reported to fit... If you are looking for a strong, cheap replacement AFIK you are SOL...
