Topic: Steel Cowl is on. (Read 1477 times) previous topic - next topic
Steel Cowl is on.
Thought you guys may be intrested in seeing the progress on it.
Just need some final touches put on it, and throw on the paint.
Bought the paint (rose quartz), reducer, hardener, and clear coat for it today. costed $116 for all of it, and may have enough to paint the saleen wing too. :hick:
Steel Cowl is on.
couple more pics.
Steel Cowl is on.
Sweet:D . Now, uh get rid of the wire wheels;)
Steel Cowl is on.
That'll happen in a couple of days.  First I have to change the TV Cable, then Saftey and E-test it.  Then I will put the rims on it that are on the gray bird, for now.
Steel Cowl is on.
Hardly recognize it! Nice work. Did you get the idle sorted out?
Steel Cowl is on.
Hey Bird brain.  Yeah, the timming was out.  Plus it definatly needs a tune up.  Grabbed the distributor to adjust the timming and got quite a shock from it.:hick:
