Topic: brake booster (Read 1838 times) previous topic - next topic
brake booster
ok folks i need some help ive got to change out my brake booster on my 83 cougar and ive never tryed anything like this before so any and alll help would be great thanks alot :bowdown:
 joe
1983 v8 302 cougar
ok for some reason some thought it was a good idea to post neg about how long my sig was in my post when it was within the letter amount so ill ask whats your problem :flip: :flip: :flip:
myspace page
http://www.myspace.com/caffine231
brake booster
Shouldn't be to bad. The hard part is getting under the dash to undo the bolts and the rod to the brake pedal. Then depending if you buy just the booster or the booster master cyclinder combo. If you just get the boost unbolt the to bolts that hold the master cyclinder  to the booster. carefully push the master cyclinder away from the booster. then remove the booster and instal the new one. If you are also replacing the master cyclinder you need to just disconect the brake lines and replace the combo unit and hook up brake lines and bleed the brakes. Hope this helps. Are you sure its the booster. That would mean hard pedal all the time.
brake booster
Pull out the driver's seat and lay a blanket on the floor so you can lay on the floor and get up under the dash. Some of those nuts are a total bitch to get at, especially the top right one.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
brake booster
Quote from: ipsd
this isnt true,  in my 79 cougar the pedal isnt hard but it takes it a while to come back, if you stomp hard on them the tires will lock up and remain locked up until it releases. now I dont know what his symptoms are so its really kinda hard to say.
brake booster
Hard pedal is what I had when mine went out but it is not the only thing that could be wrong with it. Sorry my bad!
brake booster
well ive got a soft pedal and it sounds like air leak i think its got new rear shoes and new front pads and new hubs
1983 v8 302 cougar
myspace page
brake booster
Soft pedal could indicate a bad master cyclinder. If the bosster is good and the master is bad maybe that air leak sound is the booster trying to make up for it. Not sure juat and idea. Maybe you have a leaky hose or wheel cyclinder. Maybe even air in the system, or a hole in a metal line. Look over the whole system and have someone work the breaks while you look at everyline. Also check the back side of the rims for any sign of brake fliud. When my rear W/C leaked I would see fluid on inside of the rims.  Just some thoughts to help you get it figured out.
brake booster
With my 87 sport I had soft pedal w/ hissing and thought the car wasn't going to stop. The brake booster was replaced and problem went buh-bye.:D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
