Topic: 85 front clip on 83 (Read 2119 times) previous topic - next topic
85 front clip on 83
Hey guy's and member's;  Can I put a 1985 t-bird front clip whole thing, on a 1983 T-bird thanks for any and all help here  Barry
85 front clip on 83
yes you can, here is a place where you can find all of the info like that http://www.coolcats.com :D  enjoy
85 front clip on 83
Yes. Everything should bolt up just fine as far as I know.
85 front clip on 83
Quote from: 88turbo
i think u meant coolcats.net:D
i do that sometimes also
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
85 front clip on 83
Well since I have an '85 nose on my '83....I think it should work just fine.
Actually they are the same pieces.
85 front clip on 83
Quote from: grutinator
ooooooooooops:giggle:
85 front clip on 83
Wouldn't that basicly be a grill change. Unless it's some sort of aftermarket unit. The 83 being the Square style grill and the 85 being the floating bar type grill.
85 front clip on 83
I here ya about the grill,  but what I was asking is that, does the fender's and hood and all the front all bolt right up
85 front clip on 83
Quote from: niizhmkwa
They are exactly the same save for maybe the hinges on the hood, so grab the ones from the 85 if you are swapping hoods too.
85 front clip on 83
The 83 and 85 front clip can be interchanged.but be carefull when it comes to the hood and hinges. I did the swap once and found that the distance between the hood mounting bolts to the hinge were different,probably by half an inch. So mixing 83 and 85 hinge - hood didnt work. But the whole assemble is interchangable.
85 front clip on 83
Well the 88 turbo coupe hood bolted right up to my 84 t/c hinges. The only difference that I know in the hinges it the the 85 up have the self supprting hinge where the 83-84 had the regualr hinge that you need the prop rod for. I've also got a 86 header panel and 86 passenger side fender. Everything bolted up just fine.
85 front clip on 83
thanks guys Sounds good gonna start the change next week  thanks loads again Eh!!  Barry
