Topic: Newly purchased eye candy (Read 1977 times) previous topic - next topic
Just purchased these from Brother's Performance. Baer 13" fronts and 13" upgrade to the rear. Since I switched to 17" rims i've been having the itch to do something about the rotors since their so visible now, especially when the factory rears are dwarfed by the front. More pics to come once their installed.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Yikes!  13's all around?!  That's insane.
Quote from: Ifixyawata
I like to think of it as being different.:D
So when you stop, will you be giving change or keeping it all??
Hope all goes well
Daniel
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Nice, wish I had those. 13" is like a  pizza!
Quote from: xr7cat
Hope all goes well
Daniel
LOL...well, for those times when im carrying really annoying passengers i'll be giving change....other than that i'll dial it back with the adj. prop. valve if I have too to keep it balanced.
i want to do a brake upgrade but 13s all aroud is crazy! itll look sweet when  its done
cool, whats the scoop on the rears? jusr rotors and an adaptor plate? does it use factory callipers? cobra or sn95 brackets?
ive got a whole extra  m-2300-k kit im going to be looking to unload. i was going to use it to offset some 4 piston brembos for the front.
~John~
They use GT calipers and brackets, and come with an adapter bracket. I was looking at that setup myself.
Quote from: shame302
Yep..im running a 97 GT rear. All the bracket does is relocate the factory caliper to make room for the larger rotor.
Quote from: Ether947
Uhm... what are you using in the front? Are those Baer rotors just Cobra replacements?
http://www.corral.net/forums/showthread.php?t=662776
http://www.corral.net/forums/showthread.php?t=551321
Im running 94 Cobra's in the front. The Baer rotor is simply an aftermarket replacement.
Those are awesome.  I don't think there's anything crazy about having 13's all around.  It's always looked off to me to see small disks on the rear even though it's unecessary.  I mean it can't actually cost that much more to manufacture the slightly larger disk.  It should be law to make them all the same size.
  I was wondering if you can turn those like regualr rotors if they get grooves or warped a little?  I was thinking about getting some drilled or sloted rotors for my fronts this year but I was worried about getting them turned.  jason.
