Topic: Ignition key release (Read 2871 times) previous topic - next topic
I'm tired of using two hands to remove my ignition key.
Anybody know how to disable the 'I won't give you your key until you push me' white button under the steering wheel?
A pain it the sitting muscle.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
Duck Tape.
88 TC, Lots of Mods.
Easy, and yoou don't have to wrap your coulmn with duct tape...
Remove the plastic trim shroud on the column. Press the button a couple of times and you'll notice it is in a "U" shape in the column. Just take a couple of wire ties and secure the linkage in the up position. Reinstall cover. Mine has been this way for several years...
I just use my left knee to release it as I take the key out.
Tom's idea sounds good though.
I'm glad someone asked this question.  A small thing but it has been one of my biggest gripes. I will soon eliminate the "two-hand shuffle".
88 Cougar LS 5.0
I was actually thinking about adding it to my car.... It would tie in the hole, this 5 speed 3.8 conversion looks stock.
Anyhoo, if you take the column cover off, when you press the button you will see the u shaped rod move up and down.  Now you don't have to wire tie or do anything to it..  Just pull up on it till it pops out of the hole, then pull it to the side so it wont go back into the hole.  done.
When we had gotten our cougar, we didn't have the button assy because some one before us had removed the whole works. I have since replaced and s the original column. I'm not sure what all was missing to eliminate the button. I know this is not much help but by removing the whole button assy, you don't have to rig the button to stay up.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
What cars came with this? Mine doesn't have it..
Quote from: thunder306
I believe only the floor shift models had it orignally...
Quote from: TurboCoupe50
your lucky bob, i hated it
my 88 sport didn't have it, but my 88 LX, xr7, and tc all did. think it was an option or came with something? also, my sport came pretty plane, only one power seat, no lit mirrors, or anything fancy besides power windows/locks/mirrors. like chuck said tho, i used to use my left knee to push it in and take the key out.
Thanks guys,
Tomorrow the 'U' whatever is getting "adjusted".
BobNorway;)
1) WD40
2) Duct Tape
It's a safety thing. Allows a panic turn off of the ignition while moving. It keeps you from locking the steering wheel.
Do any of you try to press that button when driving a different car, or is it just me?
I don't even remember doing it...but I know I do. Don't see what the problem is. Its like driving a stick - over time its no different than walking.
1988 Thunderbird Sport
Quote from: BIGmeat15071
All the time, when I am in a friends car, they are all like "what you grabing at", it is the samething when you drive a clutch for a long time and get into an automatic.
I don't even notice it, my ranger has it not sure about the cat, but it would probly not bother me either way.
I think it is cool, espicaly if someone new drives your car, and try to take the key, a spend half-an-hour trying to get it out. I love that.
Oh well done with my rant.
Daniel
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
