Topic: Brake Hoses (Read 1697 times) previous topic - next topic
Brake Hoses
Using '96 calipers on an '88 5.0 Sport, what hoses do I need.  The ones on the '96 calipers are too short, and are the wrong size on the hardline end.
Matt :tg:
Brake Hoses
Too short? That's.... odd.
Are the fittings too big or too small?
Brake Hoses
Fittings on the hard lines are too small, which makes the hoses too big.
Matt :tg:
Brake Hoses
Well you have two options. Double flaring with two of these.
http://discbrakesrus.com/make/ford/fitting316716.jpg
Or finding an adapter. :)
...still can't figure out why your soft brake lines are too short. =/
Brake Hoses
Its not that they dont reach, its just that the hose is to the point that it is just about kinked up at the point where it goes into the hardline.  I just remembered that is with the car on a lift, do you think they will be ok if I find the right adapters, and with the car on the ground?  Especially if I lower the car like I am discussing in another thread?  Looks like I have some trial and error stuff to do next week.
Matt :tg:
Brake Hoses
I used SN-95 lines without a prob, I don't see why you can't either. If you lower it, then that's less travel so you should be all good.
Brake Hoses
Ok then, All I have to do is find the right adapters.
Matt :tg:
