Topic: What to do... What to do?... (Read 1193 times) previous topic - next topic
Well I decided to wait another year to drop in the 351.  SO, I have some 'new found' cash to work with.  What do you guys think I should do?  2.3L Turbo Coupe, Boost Valve, 5-Speed, Wheels/Tires.  Previous owner got a cheapy exhaust job done, I'm not even runnin' dual exhaust at the present time.  I was thinking I should just run 3 inch dual exhaust all the way back with flowmasters and then just keep it for the 351.  What does everyone think?
Quote from: kewlbird08
3" dual wont fit.
were doesnt it fit? i was thinking of doing 3" but whats the problem? i know you can run a single 3".
Give it to me.
Quote from: cougar86_89
Around the passanger side of the car entirely. Especially over the axle and around the gas tank.
Will 2.5" fit?  And will i lose too much back pressure with 2.5 duals?
With minor adjustments(IE large hammer) to the gas tank support brackets, 2 1/2" fits fine....
Stop worring about back pressure... ANY amount is BAD... IF you loose performance with improved exaust, it's time to richen the mixture...
