Topic: failed emissions (Read 2173 times) previous topic - next topic
failed emissions
Yeah thats what the guy told me he said it looks like you dint pass for carbon dioxide, so then i went into the little office and the guy told me its running rich or theres too much gas passing tru, It does seem to waste more gas for some reason... You guys think maybe they dint adjust the fuel injectors right when they put them in? ive been pretty busy so i havent tried anything yet but today is my day off so ill try to check some stuff out, thanks
failed emissions
Oh And Happy 4th Of July everyone:) Be Safe
failed emissions
Quote from: Fast thunderbird
Have you pulled codes?
failed emissions
Quote from: CougarSE
Wow.... I feal like I'm back on TRS... I must have asked for codes ten times in the past couple of weeks...
failed emissions
no i havent i took it to auto zone and it turns out they only check cars  1996 and up, so i gotta take it somewhere else ill let you guys now though.
failed emissions
Question, how did you go about replacing the engine?
If a shop did it with a rebuilt unit, there should be some kind of warrenty. This warrenty not only usually applies to the actual engine, but the installation by that shop. You should be able to take it back to them with your failure form and they should make the neceassary repairs.
As far as your check engine light coming on and turning off, it sounds to me that there is a sensor or hose that is disconnecting which is throwing the code and tripping the light. If that is the case, most likely it's a result of something the shop did or didn't do when installing the engine. I've seen this quite a bit from a pinched vacuum hose or a loose connector.
If it is a used engine that you had someone just throw in there though, you're on your own.
failed emissions
Yeah, if its a new engine, you shouldn't have any problem passing at all.
failed emissions
UPDATE: well it turns out it was the freaking catalyc converters lol. the shop replaced those and it passed! The car seems to drive even better too.:) thanks for your guys advice.
I still have the check engine light coming on and off as i drive though i think its a hose off/or loose, what should i look for? Car drives good and everything but i get annoyed by that check engine light. Also the warranty was over on the engine so i couldnt take it back there....
failed emissions
never mind there was a sensor that wasnt plug right NO MORE CHECK ENGINE LIGHT!:) Cars runs so smooth and fast i love it:)
