Topic: vaccum hose (Read 2249 times) previous topic - next topic
vaccum hose
So im toying with my electrical under the dash saturday and i come across a random hose looks like a vaccum hose under the dash right next to my gas pedal it runs up over the steering column toward the headlight switch and dissappears i cant see where it goes or where the other end is supposed to go its not cut so im sure it just came off could this be part of my cruise control? It just quit working one day on my way home from minot. Oh and btw all my heater and ac controls still work.
2004 Impala
vaccum hose
Under the hood on the vacuum tree is there a hose connected on the B/R port.
vaccum hose
if your talking about the vaccum manifold right next to the brake booster yup no vaccum leaks
2004 Impala
vaccum hose
Have a sunroof?  just a shot in the dark, but it could be your drain tube, if you have one and its large enough.
88 TC, Lots of Mods.
vaccum hose
Black rubber hose, or one of those oh-so-handy color-coded plastic lines?
vaccum hose
Quote from: Birdman
I've always been told that the drain tubes run down inside the windshield pillars and through the fenders.
vaccum hose
Yes the sunroof hoses do go down the windshield pillars on each side, these are bigger the a normal vacuum hose.
There are also a set down beside the rear window.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
vaccum hose
Unfortunately, if your car has had some body work done, they may not be in the right places.... Like mine. LOL  Just a shot in the dark anyways!
vaccum hose
No sunroof and its black vaccum tubing.  I'm thinking eric is probibly right but i was so hoping that that was my crusie issue.
2004 Impala
