Topic: 88 5.0 (Read 15193 times) previous topic - next topic
88 5.0
Really nice !!!Needs a smaller light down lower in the corner,like a fog/driving light,to fill in the void.Awesome talent you have !! Two pats on the back ol' boy.
88 5.0
talent? First time using fiberglass really. Last December doesn't count as it took a week to dry and that was only to fill in the flutes to make molds.
On a related note, people always want to get clear lenses for their stock lights. Here's the perfect reason not to use our reflectors with a clear lens...it'll hot spot/glare exactly like this, just with half the light output and less annoyingly blue: http://www.youtube.com/watch?v=QXdn_4vjisE&NR=1
Basically, NOT GOOD.
1988 Thunderbird Sport
88 5.0
Primered/sanded them 3 times now and they're getting close to perfect. Just hitting the problem spot thats deep  (to the left of the projector in the previous picture). Perhaps I should have tried body filler or putty, but I think it'll come along soon enough. A metal flake color could hide any imperfections (that I'd like to disappear altogether though), or I can go ahead with a solid black/silver. Ideas? Maybe a semi-flat black?
88 5.0
Where did you get those lenses?
88 5.0
Joshua over at izntrbl.com vacuum formed them for me. I just made the molds, sent them to him, and he formed the 1/16" polycarbonate over what I gave him. I got the molds back to perfect them some more for future lenses (need to prime and sand them down a couple times to get rid of a couple dimples, and fill in the flutes a bit thicker). The difficulty on these and cougars' is about the same as the sunfire lenses, so he priced them equal.
88 5.0
Getting there. Its so close to being perfect, that I'm about to start forming the edges of the lenses for better fitment. Although the projectors look crooked in the picture, they're aimed correctly. Lenses are dusty, as can be seen.
88 5.0
Going to give silver a try, black looks kinda off between the other two lights.
88 5.0
photoshop greatness...silver
88 5.0
Reply #39
Quote from: Seek;159782
(votes for chrome)
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
88 5.0
Reply #40
Whenever you are ready to sell lenses let me know :)
Reply #41
Quote from: CougarSE;159797
 :stupid:
1979 Ford Fairmont
[/B]
88 5.0
Reply #42
Sure, if you guys want to chip in enough to build a vacuum forming table (~$100), I will, otherwise have izntrbl.com make them (send molds to him exactly how you want the lexan formed over, minus the wax, I still haven't touched the tbird molds I plan on sending back to him). I'd love to build a setup, but don't have the money to spare at the moment, money's going out the same rate as its coming in. Outdoor electric grill, $10, decent-powered shopvac, $50+, aluminum, glass, wiring, etc for enclosure, $50. Then its just taking 2-3 hours to build the darn thing, and practicing a few times (it doesn't just work).
88 5.0
Reply #43
You have links to build threads on these things?
Reply #44
http://www.hidplanet.com/forums/index.php
Everybody there has it easy though...already clear headlights, plenty of depth, and room all around for cut up stainless steel bowls for shrouds. We're not so lucky. What you see here is all made up as I go along. If I used smaller projectors (TL's are one of the largest and have the best output, but many others come in close, especially with swapped lenses), it may have been slightly easier.
Silver looks much better, although the camera makes it look gray. Reflects a bit of light in person, no flash was used here.
