Topic: Rear shock adapter brackets (Read 21019 times) previous topic - next topic
Well like I said, I will have 5 sets this time around.  When I have them available for orders I will contact interested folks from this thread in order and go from there.
I'm all over getting these, got money on hand!
Dave
Ill also take a set. These will work well on the TC when its time for shocks and struts.
Im assuming these would also work with the SN95 shocks.
im down
I'm in for a set.
Quote from: Tbird232ci
I believe the SN95 shocks are longer than the fox mustang shocks...much closer to what we have...someone correct me if I'm wrong.
Quote from: Sick88Tbird
Nope, they are only marginally longer than the Fox stuff...no where near the Tbird stuff....
If that was the case...I wouldn't bother with these...
Would these brackets be suitable for coilovers?
Quote from: JeremyB
They are going to be stronger and more secured to the axle than the stock brackets are.
Quote from: Chuck W
*Dodge*
Quote from: JeremyB
How's this Jeremy?...I'd feel comfortable using these with coil-overs on my own vehicle.... :p
:D
I thought the main problem with rear coilovers was the lack of support where the shock mounts to the body, not the axle mount...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: Red_LX
The axle side is a weak point. If you look at MM's rear coil-over kit you will see the heavy duty shock mounts.
im interested in a set
1979 Ford Fairmont
[/B]
Well it looks like I'll have to go through the first 5 interested folks first (once I have the stuff) and then order up some more bits for more after that.
