Topic: Easy Horsepower? (Read 3404 times) previous topic - next topic
Easy Horsepower?
Quote from: David
You're in for a rude surprise.
At 20 bucks, you're only fixing things that are broken already.
my bad, i meant you'd have to do atleast 20 horsepower worth of parts and labor to feel a difference, not 20 dollars
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Easy Horsepower?
Quote from: 5.0willgo
Mustang manifold, yep... Posted above you ;)
Look for one too off a Lincoln Mark VII. They were HOs as well and the manifold is the same as Mustangs.
carefull what year tho, some had actual manifolds, some had a realy py looking header log style, and the "good ones"  looked like a actual tubular shorty header, think they were on the later ones, 87 and up?
Easy Horsepower?
Quote from: Nate
I think they were talking about the intake manifold.
Easy Horsepower?
oops... looks like its bedtime :p
Easy Horsepower?
So doing just the upper intake and throttle body will give a little boost to the SO?  I was thinking about doing the mid HO, or even the full HO, conversion, but I really did not want to dig into changing the heads since I've hardly done any engine work.
Easy Horsepower?
OK another question, if and when i install this upper intake manifold do i need to take any precautions?  Or is it just simply take out and replace?
Easy Horsepower?
Quote from: BIGmeat15071
Yep. Don't forget the spacer plate too.
Quote from: rw289
It's basically take out and replace.
Just be careful not to break any bolts.
Label stuff so you remember where it goes.
Oh and you probably should check the tps sensor after you're done to be sure it's set properly. That's easy though.
Also I don't think just the manifold will do much or anything for you. You'll need the matching HO throttle body and spacer as well.
Easy Horsepower?
makes it more responsive all around and adds a few upper rpm ponies.
Easy Horsepower?
And for the thread starter
87-93 mustang upper intake,throttle body,spacer etc
good 86-88 mustang cold air kit with large K&N cone filter
set of underdrive pullies for a 87-93 mustang
set of unequal shorty headers 1-5/8 tube
a good 2.5" exhaust with a H crossover to some hi flow lers
and a 3.73 gear from a ranger
bump the timing to 12-14* base depending on fuel
and enjoy my old 88 5.0 bird was set up similar and was a fun car to drive and got mid 20's mpg
Easy Horsepower?
:iagree:
That's about the best thing you can do to a 5.0 SO. I almost the same thing to my car and it feels completely different. I can put it sidways through a turn, but that could have something to do with the 215 section tires:rolleyes:
Easy Horsepower?
Really????
Easy Horsepower?
does that surprise you?
$30,000+ 3800lb luxury coupe better have some decent power.
Easy Horsepower?
What is in the rear for gears,go numerically higher tho get the car moving on the bottom end. Try full tube headers to increase torque as well,these are heavy cars to get moving.
Easy Horsepower?
I started mine pretty much the same way that you're thinkin about. For easy and cheap here's what I would do (actually what I did do):
1. K&N and remove the silencer.
2. HO intake and stock HO throttle body. Should be able to score both for less than $150 including shipping tops.
3. Stock HO headers and H-pipe. I got mine for $75. Or for around $120 you could buy an off road H-pipe. You wont be able to use your current cat back set up so to save some more bucks just run turn downs from what ever lers you use. Dont waste money on new 1 5/8" shorties and definitely forget about long tubes. The py stock "crimp tube" HO headers are actually good to around the 300 HP level (and you can pick them up for near nothing) so anything better is a waste of money while you're shooting for 200 HP.
4. Tune up items... plugs, wires, cap, rotor, fuel filter, etc... This stuff will probably eat the better part of $75.
5. Underdrive Pullies
6. Run as much timing as you can for the octane fuel you're using.
Do all this stuff and you'll definitely feel a big seat of the pants improvement. Then later on as get get more money you can knock out the rest of the HO conversion. Forget about "bling" items like cold air intakes. They wont improve any power over the stock plastic air box. Just focus your resources on things that will give results for the REALISTIC power level you can achieve on the cheap.
The only reason I didn't mention gears is because at around $500 installed it doesn't constitute "cheap".
