Topic: Frosty cold than super hot, A/C cycyle (Read 1102 times) previous topic - next topic
So I recharge my A/C the other day and I'm doing fine for a bout 10 minutes I'm fine. Then that frosty air gets warm again, then cold for a few minutes and then warm again. The pressure is in the normal range and I can't figure out what the hell is going on. If anyone has had this problem or can offer some suggestion please lend me a hand. I know electronics but not A/C, I don't know where to start
First what are your pressure's, what type of refrigerant? how did you recharge? with can or machine? did you evacuate the system first or did you just top off?
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
I'm running R134A. I did top off, so no evac. Took back the gauge so I don't know the exact rating but it was in the "normal range".  What exactly should I have done?  Do I need to take it to a shop or are there things I can do myself to get this working? I would like to do this myself and would appreciate any tips. Thanks.
Is it the automatic temperature control? The EATC unit on my Mark does that quite often if I use it on any temperature above 60 degrees.. so I just leave it set to 60 degrees and control the temperature with fan and vent settings. Pulled codes on it a long time ago and don't recall getting anything, so I don't know what's what.. but I'm guessing I need to find a replacement control unit.
