Topic: 21 tooth driven gear (Read 1273 times) previous topic - next topic
What rear gear ratio is most accurate for a speedometer 21 tooth driven gear and 8 tooth drive gear (as on 87 AOD TBird/Cougar?), combined with 225/60/15 tire/wheel set up? Still pondering the 3.27 - 3.45/3.55 - 3.73 gear choices without changing half the drivetrain to upgrade from a 2.73 traction-lok 7.5".
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
You just have to go the next gear size up for your gears...i.e.-3.55's-21 tooth, 3.73's-23 tooth(as opposed to 21 for a 'Stang)
However, I just had 3.73's installed and there were out of 23 tooth gears so they popped in a 21 tooth(supposedly)...my speedometer is now perfectly calibrated to 3.08 gears.  So somebody lied or they gave me more gear than I asked for(which I highly doubt).
