Topic: Shift kit ??? (Read 4613 times) previous topic - next topic
Shift kit ???
Ok, im preppared for all the flames , bullets and rocks to me for the next question, but i dont have the minor idea what is a shift kit. I only heard this word maaaany times. Some of us can explain me ?
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: Shift kit ???
it's a kit that makes your tranny shift harder/better, basically
Re: Shift kit ???
aka valvebody recallibration kit. cheep and easy way to destroy ....er ah, improve your tranny.
~John~
Re: Shift kit ???
It may be true, but only on 4 cylinder tranny....
From Coolcats.net :
The ubiquitous shift kit will firm up your shifts, prolong the life of the transmission, and give you slightly better gas mileage. Shift kits work better in conjunction with a higher stall torque converter but that's not required.
By the way, the 4-cylinder automatic transmissions (C3 or A4LD), used in rear-drive 4-cylinder Ford applications (including the Mustang and Ranger), are usually weaker pieces to begin with since they weren't designed to handle the torque of a V8. Any shift kits or souping up in these would probably hasten transmission failure
Re: Shift kit ???
Quote from: shame302
Think what you want, but I gauren-dam-tee the only reason my AOD has lived through FIVE years of abuse is the Trans-Go shift kit.
Re: Shift kit ???
I agree,  I put a TransGo in my 2nd transmission in 1998 and its still going strong
Re: Shift kit ???
Quote from: Sly1990
From Coolcats.net :
Is the better gas mileage part true? I have never heard of a shift kit getting the car better mileage.
Re: Shift kit ???
I never noticed a gas mileage difference because it was done in conjunction with my exhaust.  First 2 Mods I did to this car... Gas mileage went up about 3 MPG on the highway, but I would have to attribute 90-95% of that to a full 2.5 inch exhaust with full headers swapped in place of the stock choketubes.
Re: Shift kit ???
Its Expensive ? the difference its great with or without one ?
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: Shift kit ???
Much better shifts.  She barks the tires on the 1-2 shift and sometimes when I'm just into 4th (around 50 MPH) and I nail the gas.
Re: Shift kit ???
Shift kit for an AOD is around $110 USD.
Re: Shift kit ???
wow, I don't think i paid but half of that
I got a B&M, and I don't remember which one I got, there's the Transpak, and the Shift Improver kit.
Shift Improver http://store.summitracing.com/partdetail.asp?part=BMM%2D40263&N=120+4294925134+4294925133+300206
Transpak http://store.summitracing.com/partdetail.asp?part=BMM%2D40227&N=120+4294925134+4294925133+300223
Now that I think about it it probably was the Transpak. it came with new springs to put in, as well as the plates and stuff for the valvebody. not all that hard to do, at least when your tranny is sitting on a bench, completely out of the car :p I put mine in before putting that tranny in for the burned out one that was in the car
Re: Shift kit ???
For the B&M Shfit Kit, the one for 31.95. Do you have to pull the tranny out to install it?
Re: Shift kit ???
I don't think you have to pull the tranny out for any of them, but I put my kit in with the tranny on a bench so it was cake to do it. all you'd have to do is unbolt the pan (crossmember too likely), filter, and valve body, then put the new plate(s) in and reinstall everything. the kit I got came with springs to put in, so I had to take one of the servos (I think that's what it's called? not sure) out and put the new spring in, that spring was pretty hard to compress and get the part back together. there was one of the valves on the valvebody you have to take out, and on later ones there's a tapped hole to put in a screw to pull out the valve. mine didn't have that so i had to drill a hole. another valve needs to be messed with as well but it just slides right out.
