Topic: QA1 mustang k member (Read 2022 times) previous topic - next topic
I have scanned coolcats.net and didn't see the k member interchange listed. Does anyone know if the mustang k member fits a 88 t-bird?
Thanks fellas...
It does work from what i've seen.
A few guys have used them,there's an article in this months mmff that a guy with a 5.0l supercharged TC is using one.
I did some research at one point and found that some people have problems with the QA1 k member.
Heres the link.
More about QA1
there have been a several cars out there that have had the QA1 K-member fold up on them under hard cornering ... this is partially due to the fact that they only use tabs to bolt it in. This is not a K-member I would recommend for street use. I would recommend the AJE K-member with road race bracing .. it is made with much better quality and is much more durable for street and track use.
Here's an example of what I'm talking about ...
Notice that all of the mounting points from the k-member to the frame and suspension on the AJE unit the bolts actually go through the k-member ..
the one below doesn't have the optional road race bracing, but still demonstrates the superior quality ..
Now look at what QA1 uses for its mounting points ... little metal tabs .. and no option of extra bracing ...
Quote from: Thunderstein
got any links? not that I don't believe you but i have yet to find a single failure of that k-member.
