Topic: Should I make an offer? (Read 830 times) previous topic - next topic
...and if so, how much?
1986-1993 Ford Mustang Trick Flow Track Heat Performance Kit
All parts Have less than 200km
TrickFlow Track Heat Heads
Track Heat Intake,
Ford Racing #24 Lb Injectors,
Crane Blazer Roller Rockers 7/16 Stud,
Pro M Racing Mass Air Meter,
Professional Products 70mm Trottle Body and Spacer, Polished Finish, Trick Flow Hardened Pushrods
Specs
Port and Chamber Data:
*170cc, high velocity intake runner with port opening of 2.00" highx1.20" wide
*66cc exhaust runner volume with port opening of 1.50"x1.25" wide
*61cc combustion chamber
Valves
*CNC profiled
*2.02" intake, 1.60" exhaust, 11/32" stems, .260" tip height
*Overall lenghts: 4.960" intake, 4.980" exhaust
Springs
*1.460" diameter double with damper
*125 lbs @ 1.780" installed height
Valve Guides
*.500" O.D. x 2" Long, special Manganese bronze alloy
Trying to Sell as a Package, but may be willing to Seperate.
If anyone would like any more info and prices, contact
looks like a deal, from what i see the brand new kits are around 2k ... but they have everything including the cam
try $600 and see if you can finagle the price around ;-)
You'll be lucky if you can even get the heads for $600...and they have less than 150miles on everything...I would ask why they are being sold, then try for about $1500...there are some extras in there too.
