Topic: 84 cougar 3.8 engine/trans parts (Read 563 times) previous topic - next topic
Ok.... ill be pulling the engine/trans out of my cougar hopefully within the month.  was curious if anyone needed parts? its got a rod knock and burns oil... could be valve seals or rings not sure yet.. but intake/ heads etc are up for grabs... also the C5 transmission worked fine but i think i had issues with the kick down rod on it other than that its in good shape and id let it go for 50 obo plus shipping.... i am in southwestern oregon (roseburg) i may have some other things like 2.73 rear end gear/pinion 7.5 inch rear... just seeing if anyone needs these parts before they get put into another car for s weight..  Let me know there is plenty of time
  Sincerely
            Eric
Hey I need a timing chain cover, and all the bolts used to get it off. I had all of my bolts sitting in a bucket last winter, and my little brother dumped out the timing chain cover and bolts. Now I am not able to find most of the bolts. So if you could get me the timing chain cover, and all bolts to all the front acessories, it would be apreciated.
I can do that. it has the in tank pump so it doesnt have mech fuel pump provisions....... as soon as i can get the car down to where it needs to be n pull the engine the timing chain cover and bolts are YOURS.  shoot an offer and im sure it will be accepted lol
