Topic: It's Alive!! Not Dead!! (Read 1662 times) previous topic - next topic
I finally had time to look over the Cougar today. I checked all the vitals and found a couple plug wires worked their way loose. Oil looked fine, a little burned though. Anyways, I put the key in and she fired right up so I moved her around in the driveway. No weird noises or anything.
I still haven't a clue as to why I had my problems. Maybe the initial blow was because of the weak hose and since everything under the hood got coated in antifreeze, something got fowled. Possibly the 95* temps with high humidity had something to do with it. I'll look into it more over the next few days. But it's alive!!! Wohooo!!!
Sweet!
lol, cool avatar. :)
 Fred you work fast...  Now go through that car with a fine toothed comb!
Wow what a relief!  I'm glad to hear you got it working again Fred.
-Jim
1987 Cougar LS 5.0
Thanks guys. I'm glad it's working. How well is yet to be seen :fart:
Atleast I know I didn't bend a rod or anything of that sort :banana:
I thought that avatar would be fitting Antonio. :D
Yeah, having a couple plug wires loose and the thing only running on 6 holes will make it run like it's in its death throes...
Look her over and spend some time tooling around this weekend.  Hopefully all is well.
great news mate.... btw whats the movie/movies that robot was on in your avatar?
Number 5 from short curcuit. I am guessing. I welcome your cat back.
Good to hear Fred.
we can now change ur name to 50mightgo lol
We'll see you and your cougar at Cat Jam then! ;)
1984 Cougar Convertible
1988 Cougar XR-7
Sweet:D  Check it out and make it run great again.
Quote from: the_intimidator03
It's the robot from Short Circuit. Johnny Five.
Quote from: Bane
:laughing: Good one Bane!
Quote from: 4thqtr
If all goes well over the next couple weeks :D
thanks for letting me know bout the robot.... now to see if i can find the movie lol..... good luck with the cat
