Topic: tranny fitment (Read 2607 times) previous topic - next topic
tranny fitment
Question If I pull out and aod floor shift from an mark 7 or mustang will it fit in my bird?
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Re: tranny fitment
Yes it will. If you use a Lincoln AOD the tailshaft is longer though, meaning you'll have to get your driveshaft shortened. The Mustang AOD is the same length as your stock one.
Re: tranny fitment
cant you just change the tailshaft from the cougar to the lincoln?
Re: tranny fitment
The LSC shifter is waaay different from the Bird/Coug piece(at least my old '86 parts car was). I took one look at it and said %@!$ this, it went away with the car to the crusher. I haven't really looked at the Mustang shifter, but I would think it is similar to our cars.
The tail housing ain't a problem to swap, but it requires total diassembly of the tramsmissions to swap the inner mainshaft that is also longer on the Linc tranny. I have heard of the end of the shaft being sawed off, and then being rebeveled with a file.
Re: tranny fitment
The mustang shifter is straight and the ones fot the cougar/tbird have a bend that brings the shifter closer to the driver. On the underside I don't know.
