Topic: shifter question (Read 1270 times) previous topic - next topic
shifter question
Will a mark 7 aod shifter fit in a 86 t bird? If not, will any others work?
shifter question
No the mark shifter will not fit in the bird.
Although if you want to make it work anything can be done with alot of custom fabrication.
I put a stang slash TC modded shifter in my car due to the floor shift and stang aod.
shifter question
The MK VII uses a cable type shifter that runs through the floor... It can be used but you'll have to fab up some sort of surround as its a ugly piece.
shifter question
What about a tturbo xr7 with a c5?
shifter question
Commom, what else are you guys useing?
