Topic: Hellp Me Make A Discision (Read 1508 times) previous topic - next topic
alrighty.  I am going to buy a new engine for my birthday BUT, im having a VERY hard time desciding which one I should pull.
At a local junk yard they have a 1989 lincoln Mark VII HO Speed density.  I know that they made 225 hp stock.
Also they Have a 1993 Mercury cougar XR7 HO Mass air.
I also know that that peticular engine made 200 HP stock.
I am planning on using the heads cam and intake off the engine I pull on my 88 SO engine, while I get the new block bored out and freshened up.  Which would be my best bet?  I need to descide asap.
Im going the new cam route once I get the block set up, also Ill get the heads and intake ported.
what do you all think?:bowdown:
go with the linc, it has forged pistons
86 thunderbird elan
86 mustang coupe
:iagree: The XR7 also uses a curved intake manifold like the 94-95 mustangs.  That won't fit your engine bay quite right.  Also I am not sure the mass air from the XR7 will even work in your car since you have a different wiring harness - might be wrong on that though.  Finally, I wouldn't bother changing the heads and intake on your S.O.  How long will it take to get the other block freshened up?  You will just end up changing everything twice.
Foxless :(
well, being 18, I still dont make much so ill do it as time and money allows.
plus july 28-31 im going to Joliet to watch the nmra, hot rod and muscle car nationals and id like a bit more power before i go but I doubt the new engine will be in by then.
Ps  88 Thunderbird Sport is what I have.
8.8 TC rearend, 3.55 gears.
Quote from: outofnothing5
i'd go with the linc engine then. if it's in good shape you will be ahead with it having the forged pistons. it also has a decent cam being it's the same exact engine as the 87-92 stangs.
86 thunderbird elan
86 mustang coupe
doesnt
the 93 HO have the cobra cam?
and will I be able to reuse the wireing and such from my SO engine with the linc?
thanks everyone
the linc engine will have a few more sensors than the other ho's also the 93 ho will not fit inbetween the fenders right. but keep the so in the car then take the ho and freshen that up then change it when you have that ho ready. also the harness will work with the h0 but the timing will be different. look up on the cool cats site for more info.
Got that fox rash again!
-Resident smartass! :ies:
what do you meen "a few more sensors"?
thanks
id pull the lincoln engine and build that up if it checks out okay. rplace your 88 sports 5.0 with that all together.
the 93 cougars engine does indeed have the 93 cobra cam. same part number.
~John~
Quote from: Cougar8775
The ONLY differences with the MN12 and the Fox 5.0's is the upper intake, exhaust manifolds, and the front end accessories. There is no reason for an MN12 5.0 to not fit.
if i remember correctly there are a few emissions sensors on the lincoln engine that our fox cars don't use.
arent 89 lincolns made on the fox platform too?
What would it take to eliminate the unneaded ones?
Im wanting to purchase it this week.
ps. anyone have a decent cam that they want to sell?
i can find out for you this week. the stock mustang cam(same thats in the linc engine) is actually a pretty good cam.
86 thunderbird elan
86 mustang coupe
Your going to Joliet? Where are you from?
I have teh parts to make that SO and HO. just sitting. E7 heads, Cam, and several HO upper intakes.
If you are close you can stop and take a look.
im from down around Decatur.  I can get the engines for 250 apiece and I am looking for the best choice for a 306 transplant.
