Topic: Steering and column shift linkage (Read 1747 times) previous topic - next topic
I am wondering how to disconnect the steering column and shift linkage on my 84 mercury cougar with column shift.... i am pullin the column shift and steering section out completely to remove/install pedal assy.  and if yall know what size the bolts/nuts to remove the shaft let me know please.. ive already got the column hangin down now its all disconnected electronically and physical
Why are you pulling it all the way out?
Just drop it down from the dash.  Unplug the wires and it's just a couple fasteners and it drops down.  No need to pull the entire thing out of the car.
The only time I pulled the entire column was when I install the hydraulic pedal assy in the 84 XR-7 when I did the T-5 swap.
Every other cable pedal swap has just been done by dropping the column.
well..... that is what i have done so far..... just getting the old hanger assy out was a pain in the arse... and ive noticed the new hanger assy is slightly wider with the clutch pedal.... i dont want to go through the hell of snakin it around the column n such to get it in and out... so id like to remove column and shift linkage to make it easier.  yeah it may seem like doin the difficult way..... but to me it seems easier so im all for that lol
Have you pulled the driver seat out?
no because i have no place to set it due to the fact of working outside and its raining constantly lately and no tarp to cover the seat.... also have really bad ants outside :-|
Even if you pull it loose and move it back, it will allow you to drop the column all the way....you can even set it on the back seat.
That's what I would do before I would yank the entire column.
got parts in back seat lol..... but do ya know bout the linkage removal and the column unbolting? on the shaft in engine bay.
The whole colum just pulls straight out, after you undo maybe 4? bolts. They are right out in the open if I remember right. That was one of the first things I ever did to a car before.
On the shaft, like I said it will pull straight out, but I think there is like two bolts on the linkage itself that you can undo and pull half of it. The other half goes to the power steering.
welp i got it all done the new pedal assy is in.  couldnt get the linkage for column shift apart but i seperated that from steering wheel n lowered it as far as it could go..... then i to steerin column completely out by removin 1 bolt (after taking the bolts off from the inside on the hanger assy) but it was a pain to get back together lol. i think that section of the shaft... slides up n down kind of like a collapsing steering wheel.  but its all done. i retained the factory automatic brake pedal for a larger surface to brake on.  it comes fairly close to the clutch pedal but i think it will be alright. thanks yall for your help.  getting the transmission monday and getting flywheel surfaced.... and getting a header.... all i need now is the clutch kit and driveshaft shortening and coupl emisc things here n there
