Topic: non fox engine swap question... (Read 2134 times) previous topic - next topic
allright guys.. my friend wants to shoehorn a 460 into his 73 maverick im doing the work here..... what would be needed to do this swap?
its allready a 302 with a c-6 on it i believe the 460 has a c-6 also im not sure...
would this swap fairly easy?  lemme know
Clayton
he will probly have to use a mustangII front clip. the 385 series is a wide motor.
approx 8 and 1/2" wider than the 302 thats in it correct?
its a tight fit now... maybe i should convince him to lemme build him a 351 ;-)
thanks paul
A 351 is a tight fit in a Mav... A 460 will require a lot of cutting and reinforcement...
