Topic: Stang out..... Turbo in? (Read 5768 times) previous topic - next topic
Yep dropped the stang off right outside murphy nc today and piced up this....  ahh the joys of another turbo car
Nice find! How much you want for it? :)
Quote from: thundergrowl
:D  i think im going to hold onto it for a while. dont see many this color with the options this one has:hick:
what are the options bro?
grand national? or GNX
btw from that one picture it looks like the last 3 characters of your license plates are CKY  if so kick ass
Quote from: 87thunderbirdBlackJack
T-Type coupe
AR9 seats, reclining bucket
AU3 power door locks
A01 tinted glass
A31 power windows
A90 power trunk release
BD1 rocker panel moulding trim delete
BS1  acoustical insulation pkg
BV8 ornamintation exterior door lock cylinders
BW3 ornamentation extra roof window trim (painted)
BX5  ornamentation ,exterior moulding roof drip (painted)
B24 side window reveal mouldings (black)
B48 trim package luggage compartment
B71 wheel moulding (colored)
B72 ornamentation ,exterior moulding belt reveal (colored)
B77 ornamentation,exterior moulding w/s reveal (colored)
B79 ornametation,exterior rear end
B88 moulding body side (custom)
B89 ornamentation, exterior moulding,RR window reveal
B91 exterior moulding, door edge gaurd (colored)
B94 ornamentation, exterior emblem ,body,var 1
CD4 windsheild wiper system (pulse)
CF5 roof,sun,glass sliding,elec
C18 arm and blade WSW
C60 HVAC system,air conditioner frt man controls
C95 lamp, intr,roof,courtesy and dual reading
D55 console, frt compt,floor
D64 mirror,l/s,rh,sunshade,illum
D68 mirror o/s,lh&rh,rem cont,painted
D71 gear speedo driven
D85 stripe,body side, lower accent
E5Z speedo adapter delete (buttstuffog cluster only)
FE3 suspension system (sport)
GU6 axle rear 3.42 ratio
G80 positraction,limited slip
G87 ring gear 8.50 10 bolt axle
J41 brake system,pwr,frt disc,rr drum,cast iron
J5O brake system power
KO9 generator 120 amp
K34 cruise control  automatic,electronic
LC2 ENGINE,gas,6cyl,3.8L,SFI,V6,TURBO,H.O
MW9 Transmission,auto,4spd,THM 200, Conv clutch
MXO merchandised,trans,auto provisions,O/D
NA5 emissions system,federal, tier 0
NP5 steering wheel (leather wrapped)
NQ5  cap steering,wheel,horn,deluxe
N33 steering colum,tilt type
N89 wheel" turbo" aluminum
QYH tire all p215/65r15/n wol r/pe st tl HWY
TL6 Grille (black)
TL8 ornametation ,exterior,hood, (3.8 SFI TURBO)
TT5 headlamps halogen 4
T47 HOOD (TURBO)
T63 headlamp on warning provision system
T82 headlamps auto on/off/cont
T83 headlamps,dr,(special)
T93  lamp,tail&stop (special)
UA6 theft detterant system
UQ1 provisions for stereo
US7 antenna,power,painted radio
UW4 speaker system,6,dual frt dash mtd f/d,dual
U23 cluster,inst,trim odom
VD6 bumper provisions,frt,aluminum
VD7 bumper provisions RR,aluminum
VK3 license plate mounting pkg
V73 Tow hook delete
WO2 package SPORT APPEARANCE
Y56 merchandising package GRAN TOURING
19A stripe color accent two tone med gray met/black
54U Primary color exterior, MED FLAX (91) YELLOW BEIGE
6YX spare tire delete
62B Trim comb, light saddle cloth
62I trim int light saddle (I)
plus it has these goodies!
 Mods:
stock block, crank, rods, pistons
turbo saver biggie oil filter relocater
K+N filter
ported heads
206/206 cam
LT-1 springs
009 injectors
2 fuel pumps (intank, inline)
Red Armstrong volt booster and 93 chip
Casper hot wire
TA-49 turbo
adjustable wastegate and fuel pressure
ATR 3" down pipe
3"test pipe w/dump
Cotton 3" single shot exhaust
front mount intecooler
ramcharger fans
B+M megashifter
TCI streetfighter 200-4R transmission w/TCI streetfighter torque converter
trans cooler
torque strap
boxed upper and lower rear control arms
RR air bag
polyurethane bushings
Auto meter tach, oil pressure, water temp, fuel pressure and boost guages
Scanmaster 2.1
plus i have a custom burnt chip and even bigger injectors so it can run 30 psi. Its at 15psi now and breaks the tires loose effortlessly at any speed under 60
duhhhh i think i can say sleeper
looks nice :>
Quote from: the_intimidator03
looks nice :>
thanx this is my new street car:D
cool find. man i like it beter than the stang the hood was just tomuch coupe or not. no more swaping bigblocks. or did you swao the big blockinto the stang b4 the sale and run the 302 in the tc?  you swap engines to much lol.
Quote from: CougarCoupe88
the hood was needed for clearance, traded the big block off, 302 went with the stang, t-bird still in limbo. awaiting the right motor
:d
 you move fast man
you move fast man
I try :D
your an engine slut! hahaha..
nice car.. sleeper?!?!?! only to a ricer.. any muscle car guy will see that a mile away.
Quote from: Funky Cricket
thanks, You can hear it a ways off also:rollin:
based only on the title of the thread, i thought maybe, jus maybe, there was a turbo back in the TC.....
this is cool too i guess:evilgrin:
