Topic: HO Conversion parts needed (Read 1758 times) previous topic - next topic
I need (8) 19lb fuel injectors, a MAF computer, a MAF sensor, MAF tubes, a MAP sensor, and a HO upper intake. If anyone has anything...let me know. Thanks
Re: HO Conversion parts needed
where are you from? i have the injectors and upper intake
86 thunderbird elan
86 mustang coupe
I may have the injectors and maf from a 98 mustang GT if you think they will work (they should), but Im not sure.  I'm converting to an 80 MM MAF, and 24's so I no longer need.
Rick
I have just purchased the injectors...how much for the intake though. I am also intrested in the MAF. This is the Sensor and bracket correct?? I am in Alabama
If anyone out there also has any of the parts mentioned above let me know. Thanks
